I am working through the UI Demo Walk-through from Section one of the advanced training, and I’m struggling to get the steps working as written. I’ve followed the steps, and on this one:
I add the invoke Workflow file GetAppCredentials.xaml, and set the out_UserName to the variable I created “user name”, out_password to a secure string variable “password”, and assign “in_Credential” to argument created in the previous step to in_Credential.
I add the Type into and click steps, and I run it. Everything runs fine and as expected from this sequence. It is pulling the credentials from the Orchestrator asset and logging in.
I then go through the next step in the InitAllApplications.xaml - I add an invoke workflow file for UIDemo_Login.xaml, Import arguments and set the following:
Looking at the error message seems there is an issue with the Open aaplication activity itself.
have you done the below? set filename path to in_Config(“UiDemoPath”).ToString
Sure, it’s just the bare bones REF template, with the changes made according to the training steps. I’ve attached the files. UIPath_REFramework_UIDemo.zip (1.7 MB)
Sorry, but it will not work that way. If you want to standalone execute the xaml you will have to make sure all arguments are passed.
Please run the main so that the config is loaded and your process which is configured to use these arguments/variables between workflows/state machines will execute correctly because you have created a framework based business process.
Ok, the problem was with the documentation in the training - when I ran it from Main, it worked just as expected. When I ran the _test.xaml as instructed I ran into the issue. Thanks!
