Level 3 Advanced assignment 3 problem
Please check my work flow
The data work id is not being fetched and not entering into sha1-online code. please helpClient Security Hash.zip (1.0 MB)
The problem that you are facing is that you cant get the report of the month ?
Also, remember to use .trim to erase the blank spaces inside the generator
Hey @Pablo_Sanchez
Do not post a whole exercise solution :slight_smile: it will be helpful for others if you will guide them or give them a logical hint :slight_smile:
They will learn it in a positive manner :slight_smile:
#Personal opinion
Regards…!!
Aksh
Hi @aksh1yadav thats true, sorry :sweat_smile:
Give a little more detailed view of the issues, will be helpful for providing a solution.
this is what the error i am facing and unable to solve
Sorry, this I have already done. but this not one that is creating the problem
You have to disable activities in SetTransactionStatus.xaml, just leave this enabled as far as Client Security HashCode assignment is concerned
Which increments TransactionNumber
is your in_TransactionItem a QueueItem variable? and the variable that you are passing through it also must be queueitem
In the first instructions given, have you updated the Transaction item type in Main, GetTransactionData and SetTransactionStatus
Recheck, SetTransactionStatus variable expects a type which you are not passing.
If dataRow make it Datarow type
Thanks guys I got it solved!
