In this video image below the user fixes the Assign activity issue by changing the variable ‘filesList’ to System.String
I do not have that variable type in both my drop down menu or using the ‘browse for types’ search function. Any advice?
I can see System.String [ ] in the drop down list. And it’s nothing but array of string.
If you want that one First select Array of [T] and then select String to get Array of string.
Hi Lakshman, Array of [T] and then selecting String have worked for me! Thanks!
