Joining datatables problem Left Join where b.key is NULL
Hi I want to join 2 datatables so that I can create a list of items that are in table A but that are not in table B
In SQL it would be something like this
Select A.*
FROM tableA A
LEFT JOIN TableB B
ON A.key=B.key
WHERE B.key is NULL
as far as I can tell it can’t be done with the Join activity.
Does anyone have any ideas please?
Many thanks,
Hi @charliefik
Did you try the Join Tables activity? It is has an interface to set the options you want, please let me know if that works for you
Hi Andres,
I did already try the Join Tables activity I couldn’t see how to set the Where B.key is NULL part. I tried adding another row and putting NULL=B.key essentially but that didn’t work
Actually, I don’t think you can do that type of join in the Join Table Activity. I think you want a Left Exclusive join.
See this documentation:
In this case, from the top of my head, you might consider:
  • Programmatically do a join
  • Use Linq to join
  • If the tables come from a database, you might want to do a sql query join, using the db activities.
  • If the tables come from excel, maybe look into the possibility of using VBA or power query.
Thanks Benny,
That’s what I thought.
