In my orchestrator, job is in Running state since last 15 hours but the queue item status has changed to Abandoned from In Progress. Some queue items are still pending to be processed and are in New status. I am not able to understand the root cause of it. Any help would be much appreciated.
The workflow has executed correctly in many previous runs. Some jobs ran for more than 20 hours without any issue. The queue item status is getting updated correctly for success and exceptions cases. Auto-retry is not enabled so the item will be processed only once.
As per explanation looks like one of the item went into infinite loop so you have abandoned item…or stuck in process.xaml may be on excel activity or anything
For the job that was Abandoned, the logs appear till the time bot was processing. After that, there are no logs. The last log states that it was interacting with an element (its an SAP UI based automation).
Are you using ReFramework or any other state machine? Have you done any changes on the state transitions?
Had a similar problem before when I modified some states transitions and they were either ambiguous or the condition was not met. If a condition is not met for any transition, the process will be running forever.
Something else that you can do, but as a workaround to avoid having a process running forever is to set some trigger based conditions:
In this case it might be a problem with the activity itself. I had the same problem before during the SAP login where the activity failed to timeout.
I don’t think I ever found a definitive solution for it and for sure never had figured it out why it happens. What I did was to create a workaround for the activity/sequence/workflow I knew it was having the problem.
Create a Boolean var that can be accessed from both sequences. In one of them you will have your workflow/sequence, in the other, a sequence with a delay.
At the very end of your SAP workflow/sequence set the Boolean to True. That way you know that all activities were executed. If something is stuck for the same amount of time you set the delay on the other sequence, the exception will be trigged and the transaction will fail without being stuck forever.
I finally resolved it! The issue was bot was trying to select a value from a combo box in SAP which did not exist in the dropdown, which caused it to get stuck and stop responding. Thanks for your inputs.
