Issue with Belkin range extender wired mode?
If you have a problem getting connected on wired mode with Belkin range extender. First of all, You have to use an Ethernet cable and connect it to your computer. Then, open the web browser and enter belkin.range setup. on the first page, Enter the login id or password. Click on the get started button.Then, Your device automatically searches for “SSID”. Select the network of your router, which you want to extend. Then, click on the Wi-fi network password and click on the “Next” option to connect with your network.
When you sure that all the settings are correct. Then, click on the “Create Extender Network” Option. Then you will find a blue tick on the next page. That means you can use it.
