Can you post your workflow screenshot on how exactly you are downloading the monthly report.
Will the permission issue be resolved
“And should that type into activity be there before that read csv report? Will it solve the permission issue?”
Yes during the “Save as”. The reason you are getting that permission error is because you change the value of Read CSV before to a hard coded folder path only, just leave it as ReportFilePath
And your screenshot remove the “Type into tool bar” activity, and can you scroll up because I need to see how are you downloading the monthly report
Scroll up a little more just before the “Click Save button”
In your “Type into File Name” activity it should be ReportFilePath which is right. Have you just changed that recently from what I advised?
Yes. I have kept that name only as said by you. You meant type into file name field
Ok, try to test it again and let me know if it solves it.
Can you put a log message/writeline activity of the ReportFilePath before it downloads
Ok are you sure your “Type Into File name” is typing the ReportFilePath ?
Try simulating it to False
You meant before the read csv activity
Yes.
Can you give me the log message or writeline of the ReportFilePath after you assign the ReportFilePath before download
I mean just before downloading it’s after when you just used the Assign activity to ReportFilePath
