When running a robot unattended via the orchestrator, it will run the program on a 800x600 resolution no matter what we have in the UiPath.settings files.
I guess even if you mention the resolution, the remote desktop has to support.
" If LoginToConsole is true , the resolution is limited by the graphical card of the robot machine (which might be as low as 800x600 in some cloud environments), otherwise the resolution for a simulated RDP connection is restricted by RAM (which would generally be more permissive)."
Thanks for your feedback. I totally understand that part. Question is how can I raise this limit of resolution. My graphic card works of course at a higher resolution than 800x600, so that’s not a limitation here. Does it mean to have more RAM in order to fix that? Then the robot will start running as it is written in the UiPath.settings files?
I have much doubt about that. Do you have concrete experiences and cases where RMA was a limitation?
Luckily I have not faced any issues w.r.t resolution.
Because of some limitations (resolution, login etc.,) these issues are keep coming.
Waiting for stable release from UIPath for Remote Machine automation.
