Issue on using type info into a Web Calendar
I encounter a strange problem when i use type info activity to type a date into a web calendar, if i type info a date without number 8, such as 2022-01-27, 2022-01-29, the date can show show normally in this web calendar textbox, but i type a date include number 8, such as 2022-01-28, it only show 2022-01-2, 2022-08-01, it shows 2022-0 - 1 .
if I don’t use UIPATH, input the 8 number directly into this web calendar textbox, it can show normally.
Not sure if anyone encounter this issue before, appreciated someone can give me some advise, Thanks .
HI @Jim_Yang_1117
Try enabling Simulate Click in type into property and check once.
Regards
Sudharsan
Thanks, Sudharsan, i have tried to change input mode into “Simulate”, but same result as before, the date with number 8 can’t be type info correctly.
For 2022-01-28, it shows 2022-01-02
for 2022-01-27, it can show 2022-01-27
Can you check any blank spaces are in the date you are trying to type
Try like StrDate.trim in typeinto
Regards
Sudharsan
there is no space, the date are auto-generated, even if i hardcode to type info the date 2022-01-28 with UIPath, the number 8 also can’t be displayed
I just guessing it type info into other character for number 8 due to some key setting in this pc ,let me try in other pc and try to type this value into other text box in this pc to locate which part may cause this issue
Hey @Jim_Yang_1117
Are you still facing the same issue ?
Thanks
#nK
Yes,I just tried in another pc,it encounter the same issue. Do u have any suggestion?
The website you are trying is public ?
I can check for troubleshooting…
Else could you please post some screenshots…
Thanks
#nK
Hi @Jim_Yang_1117 ,
I understood you are using type into activity to type the data. Uipath is very fast entering the values in the ui elements like text fields. Try with delay between keys property with 0.50 (50 milliseconds) so bot will go little slow and enter the date. If it doesn’t with try with 1 second wait time between the keys and see you are able to resolve the issue. Thanks.
Hi
There is a simple work around on this
Let’s copy paste the value instead of typing it
Yes
Pass the date value as a string to SET TO CLIPBOARD activity
And then use SEND HOT key activity and use key as ctrl+v and indicate that field to paste the value from clipboard
Cheers @Jim_Yang_1117
Thanks,it is not public,it is a web application developed by third party,I just got some advice to change the input method into hardware as some web activeX may only support hardware input,let me try and share the result after the holiday.
Sure @Jim_Yang_1117
After changed the input method into hardware mode, the issue has been resolved. Thanks for everyone here.
