Issue on ui element when running on attended bot (workspace is locked)
Hello,
We are encountering a problem on interacting with this ui element (See screenshot below) we tried using simulate click, send hotkeys still unable to interact with that specific ui element and for other elements we are not encountering issues. So is there a way or new approach to interact with that ui element? TIA
Also this is the elements captured using ui explorer
Can you try HardwareEvent? And Cursor offset if necessary?
And also please check if mouse cursor move where you expect.
If it doens’t move on the button, it may be selector matter and need to review its settings.
Where does mouse cursor move to in HardwareEvenet mode? If it’s not target, it’s necessary to review selector.
I’m doing test now I will let you know the results!
The modern activities still doesn’t work hardware events cant work on the background also we tried using simulate on NClick activity still same result bot can identify the element but cannot interact with it.
If you need to run it background, can you try Chromium API with cursor offset?
I also tried this
still same result no error thrown but there is no interaction with the choose file
It seems too large offset. As cursor offset is from original point of target element, in this case, set Choose File button as target then set TopLeft , offset value X:10,Y:5 , for example.
I did use get position to get those x and y axis is there other way to capture it?
@joscares
You dont need to use offset thta way
Change the value of position to bottom left and then give 10 and 10 as offset…that should suffice to click on the choose file
Offset value is relative to the element you select and not to the whole window
Thanks for this and will try I’ll let you know the results
Hello,
New error encountered using chromium api
@joscares
then you need to go with hardware only if you need offset …
also i believe you wanted to click on choose file exactly…instead of indicating whole did you try indicating only that button…if you are unable to indicate can you try checking the visual tree if you are able to find it
cheers
Okay will let you know the result and thank you for response!
I have no issues when workspace is active bot can easily interact with that element, the main issue is that if we tried to run the bot using task scheduler and workspaces is getting locked that’s the time we are having issues with thet choose file element
You can’t run automations with the screen locked. If you’re letting it run with the screen locked then that means no user input is needed, which means it should be an unattended automation.
is there a way to not let the screen locked?
That’s up to your settings in Windows.
Can you help me with this? I check screen saver it is turned off
Screen saver isn’t the same as screen locking. Is this a company computer? If so, screen locking is controlled by group policy (your IT security department).
But again, why aren’t you running this as an unattended automation?
