Issue in FOR EACH UI ELEMENT - COM Call failure
Please help me in solving the issue, its bit urgent, thanks in advance
@Sidharth_S_Kadri
as per error looks like a element issue
try to reindicate
also if the page is still loading then you might see this error
cheers
Seems its not able to communicate with website, selector or descriptor is not valid.
Try indicating again and test it.
Even After reindicating am facing the same issue
Hi @Sidharth_S_Kadri
Try to reinstall the browser extension or check with different browser if possible. then reindicate and fine tune the selectors.
Happy Automation
Indicate Properly and try again
Hi @Sidharth_S_Kadri ,
Please check the version and install the Latest Version of package then restart the studio and try.
