I was using the ‘Generate with Autopilot’ feature, but I encountered several issues. Sometimes, Autopilot is able to generate a selector based on the given prompt, but most of the time it doesn’t work at all.
Why it is? Is there any setting or set up I am missing here
Thank you for your response and for sharing the documentation with me—I appreciate it. I’ve already reviewed the document, but I’m still facing an issue I hope you might have some insight into.
Specifically, I’ve noticed that the “Generate with Autopilot” feature works intermittently. Sometimes it successfully generates selectors based on the same prompt, but other times it fails to respond or generate anything at all. This inconsistency is occurring even though I’m working with a very simple scenario—just three elements on the screen.
Have you encountered a similar issue? Any suggestions or workarounds would be greatly appreciated.
In my case, I’m simply trying to use Autopilot to identify or generate selectors for just three elements on the screen. Despite the simplicity, it still fails to detect those elements consistently.
What’s particularly puzzling is the inconsistency—sometimes it works perfectly with the exact same application and prompt, and other times it doesn’t respond at all. Have you experienced similar behavior?
Any insights or suggestions would be greatly appreciated.
