Is there a test endpoint for using the Automation Hub OpenAPI?
I would like to know if there is a test endpoint or parameter that can be used while I work out the code to manage our organization’s Automation Hub users using the OpenAPI?
HI @johansec
You can access the automation hub through Orchestrator based on API
Thanks
Ashwin S
Hello @johansec,
Please check the Automation Hub Open API documentation.
Kind regards,
Iulia
That strikes me as a lazy answer. Of course I checked the documentation, the forum and the general internet before posting this question. I don’t need the answer now. I worked out my code using the production API endpoint.
@johansec, if you would to experiment with Automation Hub in a sandbox (Open API or some other features), there are several ways to do so:
  • You can start a free trial at Automation Hub - Automation Pipeline Management | UiPath and use it for your test purposes (in this way, you test the production API without handling sensitive company-related data).
  • If your company is enrolled in the Insider Program, the Multi-tenancy Private Preview for Automation Hub, then you can enable the usage of Automation Hub on a test tenant, and again, test various capabilities including the Open API, without the need to do it directly on your Production tenant.
I am certain you already discovered this resource, which addreses the topic of Open API and user management.
Kind regards,
Iulia
