Is not declared problem
I created 2 arguments
String DateS= dateTime.Now.addDays(count).toString(“yyyy-Mm-dd”)
Int count=0
And gives me an error with count is not declared!
Can you help me please
@N_Qahtani
1st the Mm should be MM for the month
2nd check whether you are passing arguments correctly
Check as below
Hope this helps you
Thanks
Ur count is it an argument?
The date I declared it an argument
And it’s keep displaying an error
@N_Qahtani
Can you share your workflow, can check for the error
Thanks
I can’t share it bc I’m working on a server
But the workflow is going like this
Sequence > while loop (which is the dateS and count is located)> sequence > invoke workflow ( i need to use dateS and count here which is the reason to put arguments instead of variables
@N_Qahtani
Okay, check as below for your reference
New_flow.zip (3.5 KB)
Hope this helps you
Thanks
