Is it possible to work in Bot machine while workflow is executing from Orchestrator to Bot machine ?
Thanks in advance!!!
If the process in something like screen modifications or type into activities which will work only when they are visible on the screen, then you don’t have to open or disturb the machine.
If it is anything that can be performed background, then you can do
usually, it is better not to disturb the machine
Thanks for your solution
One more doubt… in case, i created the workflow for screen navigation screenshot and upload to orchestrator inorder to run in bot machine. so while the job is executing in bot machine, is it possible to work in another application (working in other application which is not related to uipath application) in bot machine?
The same answer as above @baalajee_k,
It is same for all the machines . even it is a bot machine or the development machine
May be I’m wrong
Thanks
