I have an Excel sheet, and using Read Range, I get a DataTable object (dt_All), and this has 3 different parts, each of which needs to be processed differently. The 3 parts are separated by an empty row like:
As you can see each section has completely different structures, so they need to be processed differently, but I am reading this whole table at once, so I can separate them later. This way, I don’t need to use Read Range 3 separate times.
I created a logic that returns an array of Int32 (arrEmptyRows), containing the row index of where the empty rows exist. In the above example, the returned array will be like {6, 11} because these are the empty rows.
Now, using arrEmptyRows, I want to retrieve each section from dt_All. How can I do this? Like first, I want to chop off any rows after arrEmptyRows(0) so I can only get the DataTable object of the first section.
Then, after I finish processing the first portion, I can now chop off rows before arrEmptyRows(0) AND rows after arrEmptyRows(1), because that will produce the second section of dt_All.
Is this possible?
