Is it possible to extract more than heavy data from SQL Database using UiPath?
More than 1000 records from SQL DB
yes. It is possible even more than 1 million records.
Regards
Balamurugan.S
so have your tried it means i just want to be sure while interacting with client.
@omkard222
I often use the SQL activities to return large amounts of records. To the best of my knowledge they work exactly as I would expect and return all of the data that you would get if you queried the database with any other tool like SQL Server Management Studio.
