Hi Guys
I have a Problem
I want to use an activity Invoke VBA
*.txt file has chinese(UTF-8)
but VBA read just ANSI Endoing
How can I change Encoding with VBA and execute ???
thx
Hi Guys
I have a Problem
thx
Can you try to convert to proper character encoding in advance as the following?
thx,
Can I see encoding options?
Unfortunately, I don’t have environment to check it.
There is a list of encoding for .net. So can you try some Chinese encoding (such as "gb2312"
Hello,@111634
1.
