If you have WI4 present then you can check if the elementExists for next page is working correctly.
you can IM me your project zip and i can have a look and highlight the areas with issues.
How could you solve the error?
How are you, i am also having the same problem you were having can you please help me on how you solved it
Hi I am also facing same issue can u tell step by step how could u solve this?
I m also facing same issue can u tell step by step?
Hi @Sharmi1 ,
There are multiple issues discussed in this topic and there could be multiple scenarios for which the original error message is obtained when running the code. Could you share your workflows (zip archive with the project) and the error message (screenshot) that you receive when executing the code? This will bring more clarity on the issue. Thanks!
Thanks for ur reply.error cleared
