Invoke Power Shell problem
Hello everyone,
I have a problem with Invoke Power Shell.
i need run PDF with powershell and i use activiti “Invoke Power Shell” with this CommandText:
“C:\Program Files (x86)\Adobe\Acrobat Reader DC\Reader\AcroRd32.exe /A " + strings.Chr(34) + “zoom=175” + strings.Chr(34) + " " + strings.Chr(34) + “C:\test.pdf” + strings.Chr(34)”
I get this Fail:
Invoke Power Shell: The term ‘C:\Program Files (x86)\Adobe\Acrobat Reader DC\Reader\AcroRd32.exe /A “zoom=175” “C:\test.pdf”’ is not recognized as the name of a cmdlet, function, script file, or operable program. Check the spelling of the name, or if a path was included, verify that the path is correct and try again.
Please, help me :).
Thank a lot
Can you try mentioned as follows:
So I finally solved it through VB.Net code :slight_smile:
Code:
Process.Start (“C:\Program Files (x86)\Adobe\Acrobat Reader DC\Reader\AcroRd32.exe”, _
“/A ““zoom=” + StrPercent + “”” “”” + StrPath + “”“”)
It opens a PDF with arguments that are taken from variables.
Maybe it will help someone.
