How to solve AuthorizationManager failing for Invoke Powershell activity ?
Root Cause: The issue generally occurs if
- Either the PowerShell script file that is being called in the command is blocked by Windows
- or the PowerShell command refers to a module that is blocked
- or one of the out of box MID Server PowerShell script is blocked.
Resolution: Unblock the script file in the file property.
To unblock multiple files, use the commands below:
dir ls scripts -recurse | unblock-file
