Installation Issue...System.IO.DirectoryNotFoundException
#1
I am not able to install the UI Community Edition on the machine. It is giving installation error… I had disabled the Antivirus software on the machine. Still it is not working. Kindly let me know what need to be done for proper installation of the software…
2017-11-18 15:44:18> Program: Starting Squirrel Updater: --install .
2017-11-18 15:44:19> Program: Starting install, writing to C:\Users\HP\AppData\Local\SquirrelTemp
2017-11-18 15:44:19> Program: About to install to: C:\Users\HP\AppData\Local\UiPath
2017-11-18 15:44:20> CheckForUpdateImpl: Couldn’t write out staging user ID, this user probably shouldn’t get beta anything: System.IO.DirectoryNotFoundException: Could not find a part of the path ‘C:\Users\HP\AppData\Local\UiPath\packages.betaId’.
at System.IO.__Error.WinIOError(Int32 errorCode, String maybeFullPath)
at System.IO.FileStream.Init(String path, FileMode mode, FileAccess access, Int32 rights, Boolean useRights, FileShare share, Int32 bufferSize, FileOptions options, SECURITY_ATTRIBUTES secAttrs, String msgPath, Boolean bFromProxy, Boolean useLongPath, Boolean checkHost)
at System.IO.FileStream…ctor(String path, FileMode mode, FileAccess access, FileShare share, Int32 bufferSize, FileOptions options, String msgPath, Boolean bFromProxy, Boolean useLongPath, Boolean checkHost)
#2
Hello there,
Could you please check the permissions for that folder.
You can try again by deleting the %localappdata%\UiPath folder and try installing again.
