Info: Using ID 'xxxxxx' for connections to the remote server. Error Code: ERROR_CONNECTION_TERMINATED
Error:
Info: Using ID 'f9440097-6bed-4339-8213-c0ee4837c968' for connections to the remote server.
More Information: Web Deploy experienced a connection problem with the server and had to terminate the connection. Contact your server administrator if the problem persists. Learn more at Microsoft Web Deploy error codes .
Error: Unexpected end of file has occurred. The following elements are not closed: results. Line 1, position 550.
Resolution: Follow the steps below,
- Uninstall security software in the server and try again
- Make sure Management Services are installed (Add Role and Features > Web Server)
- Check if Web Management Services and Web Deploy Agent Service are running
- Make sure Fiddler or any other similar software is not running during the publish
- Check if TCP port 8172 are open .
