In Multi-Node OC Deployment AD Auth Sometimes Works And Sometimes Does Not Work
In multi-node OC deployment, AD Auth sometimes work but sometimes is not work, error message is "an error was encountered while handing the remote login".
Issue Description: In multi-node OC deployment, AD Auth sometimes work but sometimes is not work, error message is "an error was encountered while handing the remote login".
Resolution:
IIS had Windows Authentication disabled on the secondary node, Enabling the same and restarting the IIS resolves the issue.
Steps to perform:
  1. Open IIS (Internet Information Services Manager)
  2. In the Connections section, under the Sites node, select UiPath Orchestrator
  3. In the main panel, double-click Authentication to view the details
  4. Select Windows Authentication and then, in the Actions panel on the right, select Advanced Settings.
    Note: If not already enabled, enable Windows Authentication to continue with these instructions.
  1. Click the UiPath Orchestrator site on the left, and then double-click Configuration Editor in the main area.
  2. In the Configuration Editor, along the top, from the Section list, select system.webServer/security/authentication/windowsAuthentication.
  3. For useAppPoolCredentials, set the value to True.
