IMAP Activity- SSL connection problem
I’m facing an issue while using the “Get IMAP mail messages” activity. Mentioning the error here.
20.10.2-beta.4+Branch.release-v20.10.2.Sha.4159e362988a0a006fae50b97bcda221e51a99d6
Source: Get IMAP Mail Messages
Message: An error occurred while attempting to establish an SSL or TLS connection.
One possibility is that you are trying to connect to a port which does not support SSL/TLS.
The other possibility is that the SSL certificate presented by the server is not trusted by the system for one or more of the following reasons:
  1. The server is using a self-signed certificate which cannot be verified.
  2. The local system is missing a Root or Intermediate certificate needed to verify the server’s certificate.
  3. The certificate presented by the server is expired or invalid.
See MailKit/FAQ.md at master · jstedfast/MailKit · GitHub for possible solutions.
Exception Type: MailKit.Security.SslHandshakeException
RemoteException wrapping MailKit.Security.SslHandshakeException: An error occurred while attempting to establish an SSL or TLS connection.
Need guidance to solve this error. Have tried changing security settings in Mail and deleting SSL certificate from internet options.
@haaritha_aarifin
Welcome to forums
Can you share the properties of the IMAP activity?
Also check any Firewall / Antivirus is blocking the request
Try disabling Firewall / Antivirus
Hope this helps you
Thanks
Hi Srini,
It helped me after disabling antivirus. Thanks a lot :slight_smile:
