We’re eager to hear from you!
If you have any ideas, issues, or improvement suggestions relating to the Academy Idea flow customization in UiPath Automation Hub course, please feel free to add them to this thread.
Hello @Cristina_Danovschi!
It seems that you have trouble getting an answer to your question in the first 24 hours.
Let us give you a few hints and helpful links.
First, make sure you browsed through our Forum FAQ Beginner’s Guide. It will teach you what should be included in your topic.
You can check out some of our resources directly, see below:
Always search first. It is the best way to quickly find your answer. Check out the icon for that.
Clicking the options button will let you set more specific topic search filters, i.e. only the ones with a solution.
Topic that contains most common solutions with example project files can be found here.
Read our official documentation where you can find a lot of information and instructions about each of our products:
Watch the videos on our official YouTube channel for more visual tutorials.
Hopefully this will let you easily find the solution/information you need. Once you have it, we would be happy if you could share your findings here and mark it as a solution. This will help other users find it in the future.
Thank you for helping us build our UiPath Community!
Cheers from your friendly
Forum_Staff
Idea Flow customization is a powerful addition to UiPath Automation Hub because it enables businesses to align the automation idea lifecycle with their unique processes, priorities, and governance models**. Instead of being confined to a fixed sequence, organizations can now define their own stages, rules, approvals, and data collection points—making Automation Hub truly adaptable to any enterprise structure.
