Friday, June 22, I don’t know if it’s after the UiPath update
Currently, MS EGDE-based processes stop working in the EGED activity section, and the output window shows Check UiPath Extensions. Is there a solution?
HI,
For now, can you check the following page?
Open the edge browser and check for the extension once. If not available then enable it once
Hi @sssim4567
Might be the extension of the UiPath in the Edge browser is removed or turned off.
Follow the steps,
→ Open the Edge browser
→ Click on the Three dots on the top right corner
→ Select the Extensions option from the window.
→ Click on Manage extensions
→ Go to My extensions check the UiPath is available and truned on, If not search for the UiPath in the search bar and toggle on the option.
Hope it helps!!
