I am trying to automate desktop. I click on the start and chrome, I need to right click on the Chrome and select as administrator. Right click on Chrome is appearing, after that it doesn’t identify the menu.
Hi @ramya_raju and welcome to the forum.
In order to use submenu in rigtht-click you need two separate click’s
First right click as you already have done and then…:
To capture the submenu in the second click action you need to bring the submenu to front before selecting item to click.
- Select Indicate on screen
- Press F2 (this gives you a 3 seond break to bring the submenu to front by rigthclick it.
- Select the item from the submenu you want to use.
/B
