I need help with a process in studio (description below)
I need to create a new process that could be shared across queues using a configuration document to control which queues, file shares, file filters, to be used to add items to the correct queue.
Will compensate.
Hey @Marilyn_Jefferson
Yes thats possible.
But if you can explain your business case a bit more detailed, will be great to understand!
Thanks
#nK
