I need help to resolve below issue
I have an Data table values which are not in same position for every run.
Example : row(0) is having all the values as mentioned below. I need to pick only Mobile and number fr that DT… Also for every sheet the mobile no won’t be in same row it may come at row(9) or row(10). Also this data won’t be having header…
  1. Member
    Gender: male
    Is international
    Disability
    Qualification
    Mobile 1110000111 email id
    Note : eligible
    Number status 0
Above mentioned all details will be in one column with spaces in between
I need only mobile 110000111 value in one sheet else one variable
You can write to text file
Then with the help of regex you can extract the phone number
and then you can write it into the sheet
Can you send me input sheet so that I can give a try
and get your requirement
Hi @Shru_6 ,
One of many ways :
  1. Use Output Datatable activity to convert the Datatable to Text. Let’s say the Output variable as strDT.
  2. We can then perform regex operations on this string data.
(?<=Mobile\s+)\d+
Expression :
System.Text.RegularExpressions.Regex.Match(strDT,"(?<=Mobile\s+)\d+").Value
@Shru_6
array=datatablevariable.AsEnumerable.select(function(x) x("Columnname).tostring).where(function(r) r.contains(“Mobile”)).toarray
cheers
Processing: IMG20230824150705.jpg…
I did not get the input please check once
How to use expression after output data table…
Please share screenshots…
Hi @Shru_6
Try this:
mobileNumber = System.Text.RegularExpressions.Regex.Match(row("YourColumn").ToString(), "(?<=Mobile\s)[\d]+").Value
Hope it helps!!
Take assign activity then
in save to—take one variable
in value to save–System.Text.RegularExpressions.Regex.Match(strDT,“(?<=Mobile\s+)\d+”).Value
take write line and give that variable
I used this expression I am able to see result in array of string, how ever I will be having different sheets I need to go to each sheet and fetch only mobile numbers…
Please elaborate with ss…
@Shru_6
Use Getworkbook sheets Activity it will fetch all the sheets names
Use For Each and pass the output of worbook activity
inside use read range activity and in the sheets pass the Current item
below that use the above mentioned syntax you will get the output
cheers
if you face any issue let me know
Mobile no is null
Hi @Shru_6
Can you share the dummy data excel so that we can help you.
Regards
Dear Shiva,
Thanks for clear information,
correct me I am facing issue check ss
@Shru_6
see by using for each row and checking the each row will it take more time as which Parvathy
mentioned
@Shru_6
make
item.tostring
It will works
cheers
Hi @Shru_6
Use the below regular expressions
System.Text.RegularExpressions.Regex.Matches(yourstringinput.ToString,“((?<=Mobile\s*)\d+)”)
Hope it helps!!
Sure
