I am using Read Range from excel, Filter it & Paste in a same workbook it works fine
Q1.However, when I use in Actual sheet it gives me an error of Invalid Links.So, if i remove the Invalid Links Will it work?
Q2. How can I ask UiPath to Read from one workbook at write in another workbook?
@Raks_K
You can use copy paste range activity
or use read range and write range
also try with workbook activities if excel activities are throwing some error
cheers
Thanks Anil for Answering Question 2.
Can you help with Question 1 as well?
@Raks_K
the answer is for both
ideally if you remove hyperlinks it should work …or with hyperlink workbook activities should work
cheers
Thanks I will try this out on Monday & Report back
I am getting the below error:
Write Range Workbook: A malformed URI was found in the document. Please provide a OpenSettings.RelationshipErrorRewriter to handle these errors while opening a package.
