I am using Automation Cloud, for automation of WordPress post publishing, how to start?
I am in Automation Cloud and want to automate WordPress post at draft status to publish after editing. How can I start?
So far, I got 2 options, which I could not, don’t know how to, follow from my Automation Cloud
option 1:
  1. Open the UiPath Automation Cloud portal and navigate to the “Library” option from the left sidebar.
  2. Click on the “New” button and select “Process” from the dropdown.
  3. Give a name to your process and select the “Blank” template. Then click on the “Create” button.
  4. On the next screen, click on the “Dependencies” tab and then click on the “Add” button.
  5. In the search bar, type “WordPress Activities” and select the package from the results.
  6. Once you have selected the package, click on the “Add” button.
  7. After adding the package, you can now use the WordPress activities in your workflow.
Reason: No library options available from left sidebar
Option 2
  1. Open your UiPath Studio in Automation Cloud.
  2. Click on the “Projects” tab and create a new project or open an existing one.
  3. Click on the “Dependencies” tab on the left-hand side of the UiPath Studio interface.
  4. Click on the “Manage Packages” button located at the top of the dependencies tab.
  5. In the “Manage Packages” window, search for “WordPress” in the search bar.
  6. Select the “WordPress Activities” package from the search results and click on the “Install” button.
  7. Wait for the package to be installed, and then close the “Manage Packages” window.
  8. You should now be able to use the WordPress activities in your UiPath project.
Reason: After I create a new project, cannot locate “Dependencies” tab on the left-hand side of the UiPath Studio interface.
Please provide guide,
Thank you.
