I am not able to see "Create blank project", "Simple process" etc options in the New project section
Not able to see any option to create a new project. By the time I get your response I will try to re-install the studio. Please let me know if you need any other details so that you can look into and resolve.
Thanks a lot
This is the screen I am seeing
Hi @Aniruddh_Rathod , Welcome to UiPath Community!
On the right side you can see New Project. Under that there is Process, which will create a new process if you click on it.
Hope that helps you.
Robin
See here the yellow arrow.
Regards
Balamurugan.S
Thanks. Balamurugan It worked very well for me.
