I am facing a problem after joining tables
I tried with preserve format , but i am still getting this error “Column 2(Emp Id) datatype is not supported”
If you already have Table 2 in a datatable then why are you writing it to Excel then reading it back in? That makes no sense.
You’re doing it backwards. You shouldn’t use Object as a column datatype.
Make them both String.
How should i convert object type column to string type ?
Hi @P-A-J ,
I believe the input excel sheets were not shared ? Could you share them so that we get a clear Idea on what is the data/data format that you are dealing with, this would help us to provide accurate suggestions towards your case.
Set them all to string in your Build Datatable for Table 2.
Use workbook Read Range to read the Table 1 Excel file and they’ll be string not object. For whatever reason, I had to check the PreserveFormat box for this one to read properly.
He sent them to me by PM and I had no trouble getting them to work and have given him explicit instructions on how, so I don’t know what the problem still is.
I am using workbook activities and even though i used preserve format , it is still not joining the tables properly
Hi @P-A-J
Please check the code
MergeDatetebles using linq.zip (10.4 KB)
let me know if that works
Happy automation
You said you are building one of the tables in your automation, and that you used Object as the datatype for the column. I keep telling you don’t use Object, use String.
No no , the schema that i built has a ID in string datatype. The Emp Id that is object , is what i got from ReadRange in Excel. I dont know how or why it is giving so.
As I said, use the workbook Read Range and check the PreserveFormat box.
preserve format , Not Working
There are two Read Range activities one under Excel and one under Workbook. Which are you using?
Use the one under Workbook.
Workbook read range , which do have preserve format option
