Hi All,
Best Wishes to all,
Is there any feature available that allows User and Robot to work on same machine at same time?
For eg : Bot will perform its define tasks and Human start its daily working using same environment.
Thank you
Hi All,
Best Wishes to all,
Thank you
Hello @ScotQ ,
You should check PIP feature
This might be the feature that you’re looking for.
Vasile.
