HI,
I want to draft a mail, and in draft mail, I want some text in bold format.
Is it possible in smtp activity in property of body to write some text in bold format?
like:-
First Name Last Name
ZZZ AAA
XXX YYY
HI,
like:-
ZZZ AAA
XXX YYY
Enable the IsBodyHTML property and then you can simply wrap the words you want with bold with
"<b>First Name Last Name</b>"
br,
Topi
Thanks @Topi , Its working.
One more thing, how to space between two strings in body property in smtp activity.
like:-
zzz"TABspaceTABspace"aaa
xyz"TABspaceTABspace"abc
if you don’t want to go with CSS styles then a crude solution would be something like this:
Insert white space of different widths. You can insert a longer space by using any one of the following options:[3]
Two spaces - Type in  
Four spaces - Type in  
Tab - Type in
source:
Keep it inside the quotations.
I tried that, it is create a string like:- ZZZ AAA
XYZ ABC
Any solution for same???
Thanks.
You are missing ; character.
Try this in your body:
"<b>First Name Last Name</b><br>ZZZ AAA<br>XXX YYY"
<br> is a line change in HTML
Check this out for additional info:
You might want to use a table since it looks like a tabular format anyhow:
Input like this:-
and output:-
First Name Last Name Email
ZZZ   AAA abc@def.com
XXX YYY ccc@ddd.com
it is not work. It only write between two strings.
Are you not seeing my earlier reply ?
