How to write a excel cell using row and column index using WriteCell Activity?
Like in Excel VBA itself, we can write using (1,1) (2,3) etc.
Hi @abskulkarni,
Use “Write Cell” activity and specify the range to write in particular cell.
Provide the value in “Value field”, include the activity in Excel application scope.
Hope this will help.
Thanks,
Girish
Hi Girish
No. The range should be in the form of numbers like 1,1 or 4,5 etc; and not like “A1”, “B3” etc. Range parameter of WriteCell activity does not take “number, number” format.
Hi @abskulkarni,
Write cell doesn’t take number as parameter, since it is excel cell, it will take only “A1:A5”. If you want range to be decided at run time then you can use counter to change range at runtime.
Thanks,
Girish
Hi @Girish
You may use this solution to first convert the Column numbers to Alphabets,
then use write cell
Excel_Column_Name_Mapping
Hi, @aksh1yadav, thanks for your Column_Name_Mapping. It workable to convert the column numbers to Alphabets.
Would you please tell me how to convert alphabets to column number?
eg. Convert Column"A" to “1”, Column “B” to “2”, … Column “AA” to “27” etc.
Thanks,
Karen
Hey @karen_li
Super Busy … but i have already this workflow
please find attached one and let me know
Convert Excel Col name to Col Number.xaml (9.7 KB)
Regards…!!
Aksh
Thanks a lot! Very kind of you~
Karen
Can you please tell me how to convert column number to alphabets?
Hey @arunshiva
Follow existing Link - Get last column of Excel sheet in Alphanumeric form - #7 by aksh1yadav
Regards…!!
Aksh
