The question is self explanatory. Would it be possible to work on the same Ui Path project with a group of people? Is there a way to share certain parts of the project like git does with regular code?
Thanks in advance.
Thanks in advance.
Sure, with Invoke Workflow you can each work on a different part of the process then tie them together in your State Machine and Flowchart framework. You might want to map out the variable structure and design standards to keep your project consistent.
Those are my thoughts. Thanks.
Thank you very much for great insight, that helps a lot!
