Ok, you can build your own Datatable, also don’t include the headers in excel sheet, because It will throw the same exception already belongs to this DataTable
The cause of this error: data in first row is same with second row.
You need to read data from Excel files with specify range.
Please refer as below for guideline
(*Please chnge file path in below sample workflow first) ReadRange.zip (21.2 KB)
HI I am new to RPA can i read a column by its name? my column position is not fixed and i want to locate it by its name in my process… I tired to put the Column header in the Range but I’m getting error as it needs cell number…but i cant put cell number i need to find it by its name…is there a way to achieve thiss…
