I was wondering if i could use regex expression in flow Switch ?. For example the input string could be “User not found – Reg Error” or “Variable not found – App Error”. I want to have the same FlowNode that would work for both these strings. How can i make this work ?
You can just have 2 lines going to the same direction with both text
You can use either “NOT FOUND” or “ERROR” as your line then use an If condition inside the string condition for your switch. For example, If(text.ToUpper.Contains(“ERROR”) and text.ToUpper.Contains(“NOT FOUND”),“NOT FOUND”,text.ToUpper)
I like your approach @MDSamnan, but I think it’s sometimes beneficial to use a Flow Switch activity rather than Decision in cases like this.
Here is an example of that: Use regular expression in Flow Switch.xaml (10.5 KB)
