How to use for roop with using System.Data.Datarow input
hi everyone.
I want to ask you all about dev using for each.
Now I want to for each roop(UiPath Activity Block) and its input value’s datatype is System.Data.Datarow but I could not compile and execute program.
is there any way to roop Datarow?
If it is not possble to roop, how can I get data from datarow?
Thanks,
@taichi, Refer the following links ,
  1. For each row error (Solved) - #3 by aksh1yadav (Description)
  2. For each row error (Solved) - #2 by Mateus_Cruz (Pictorial)
Dominic :slight_smile:
Hi Dominic
I can use for roop with using for each row!
Thank you for your advice.
Best regards,
Taichi
