i have installed FlexiCapture Engine just now ,and actived it.
but i don’t konw how to use it to recognize text in pdf.
can any one give me an example ?
.xaml is ok.
thank you very much
or to say how to use these activity to recognize the content
Hi jmy
To use the Intelligent OCR you need to first create template in FlexiLayout studio and then create fcdot file in ABBYY Administration Sation. Only after creating the fcdot file you can give the path of that file in the process document activity and then extract the data.
Thanks
Niveditha Kanhangad
i want to try it in uipath
thank you
thank you very much
But:
i ahve installed these two engine : FineReader and flexiCapture
in the service they are so alike
by the way is intellignet ocr invoke this abbyy FlexiCapture Engine ?
I am so sorry to disturb you again
1–
i don’t know how to input this property.
2–
which type of file can it recognize?
3–
thank you NivedithaK
finally i want to recognize all the content
if you hanve any idea please tell me
thank you very very very very much
http://www.abbyydownloads.com/fc12
If you have any tech support questions, please use ABBYY’s Customer Support Management (CSM) portal at https://www.abbyy.com/csm
In order to get a username and password for our CSM, please contact our CSM Representative at CSMLogin@abbyyusa.com.
Hi,NivedithaK
what if I get a datatable from .fcdot. how can I output it ?
for example if I want to output each cell to excel
thank you
I got it
Hi @NivedithaK,
Can I ask you about the version of ABBYY flexicapture and flexiengine which you used to make this projekt SampleAbbyy?
Boguslaw
Hi Bogdan,
version used is 12
Hi @NivedithaK,
So it is very weird. I used version 12.0.2.1420 to make same document definition as yours and I have error in UiPath with my fcdot, but your is working correctly. Can you generate one more document definition for this project and make some screenshots of settings which you use in flexicapture studio? It will be very helpful with trying to solve my issue.
Thanks,
Boguslaw
Afl file from flexilayout will be very helpful too.
Best regards,
Boguslaw
Hi Bogdan,
Can you please provide the exact error
There is my topic about this:
Can you send exactly versions of flexicapture and flexiengine? It will be helpful too, because there could be problem with capture and engine compatibility.
Thanks,
Boguslaw
Hi all,
Does any one knows about the pricing details of abby flexicapture extractor?. please share me the details.
Thanks in advance😊
