How to start automation
the input is the variable that i created right?
Hi @Nur_Amin
For excel the variable you crwated will
Be input and that same variable shpuld be used as output variable for previous activities like generate datatable
Thisnis the variable that i created n put as input
can u explain more on this?
Hi? Can u explain more on this?
Hi @Nur_Amin
The variable you created is of text type
That is good…When you read your text file you will place the data into this variable by giving the variable name in output field
The same string please give as input variable for generate dataatble
then output of generate datatable is a datatable so create a datatable variable and assign that variable to output field for generate datatable
give the same datatable variable as input to write range to write data to excel
cheers
may i ask for your help? can i give u a sample data and i give explaination step by step n u can help me more details on how to use uipath
