How to start a UiPath Job from power automate
We are using azure vm, how to make api calls from power automate to start the uipath jobs?.. I tried to make use of orchestator api endpoints, but if I run from power automate it throws an error saying that “our custom endpoint” is not available. Same thing if I run using postman it works fine. What am I missing here???
Hi @monish06,
You just need to use Power Automate commands to Start a Job just as how you would start a job via API. Something like this:
This should help you how to start a job via API:
I’ve tried but it throws an error saying our custom on-permis url cant accessed.
We should start in solving your trigger via api problem. What’s the endpoint your using? What’s the exact error? Give us more details - as much as you can.
