Can you try to Read the pdf by setting PreserveFormatting option as True?
for this you can use regex to split the data
for this follow below steps
1.Take one assign activity
2. Create Matchcollection(variable type) variable and add that variable in TO section in assign activity.
3. In value section give below syntax,
Syste.Text.RegularExpressions.Regex.Matches(yourstringvar, “\d+.\s*[^0-9]+”))
4. Here you will get list values where it got separted as per your scenario, you can call those value by using index or loop
If you find it helpful, please check this post as solution.
Happy Automation!!
I tried but get same solution.
did you tried this
Happy Automation!!
I trying but when I call Section6 = matchCollection(5).Value.ToString.Trim() it in the same line too.
Can you elaborate more please, what happening after calling section 6.. what is your exact input, if possible send your input as text in this thread
What you expecting output from that.
and paste your input data as text not in the image
Try to use this below regex:
Regex.Match(yourText,“6.\s(.?)(?=\s7.)”,RegexOptions.Singleline).Value
Mark solution if its help happy Automation ![]()
