How to split a 3 letter or a 2 letter city name from a string
Hello everyone :slight_smile:
I have a string variable,
ZipCode = “Salt Lake City CA 78978” or “New York NY 76521-1234”
My requirement is to split the above strings into 3 sets basically
So the output should be following format,
Salt Lake City (City Name) or New York (City Name)
CA (State Name) or NY (State Name)
78978 (Zip Code) or 76521-1234 (Zip Code)
If its a single word city name, the following is working well for me
ZipCode.Split({" “,”-“,”,"},StringSplitOptions.None)(0)
but need help with other 2 kinds of scenario !
Any help will be much appreciated.
Thanks in advance :slight_smile:
Happy Automation
HI @bibinthomas
Checkout this expression
City Name
System.Text.RegularExpressions.Regex.Match(ZipCode,".*(?=\s[A-Z]+\s\d)").ToString.Trim
State Name
System.Text.RegularExpressions.Regex.Match(ZipCode,"\S+(?=\s\d)").ToString.Trim
ZipCode
System.Text.RegularExpressions.Regex.Match(ZipCode,"(?<=[A-Z]\s).*").ToString.Trim
Hope this Helps!
Regards
Sudharsan
Hi bibinthomas,
Try below expressions.
To get a city name.
system.text.RegularExpressions.Regex.Match(“New York NY 76521-1234”,“(.*(?=[A-Z]{2}))”).Value.Trim
To get a state name
system.text.RegularExpressions.Regex.Match("Salt Lake City CA 78978","([A-Z]{2})").Value.Trim
To get a Zip Code
system.text.RegularExpressions.Regex.Match("Salt Lake City CA 78978","((?<=[A-Z]{2}).*)").Value.Trim
Thanks!
Thanks @Sudharsan_Ka
For your very quick response…
I just have one more doubt here, the above regex works well if the delimiter is space(" ")
But what if the string is something like “Salt Lake City-CA-78789-7878”
or for that matter, “Salt Lake City,CA,78789-7878”
Your response sort of helps my half concern, but when the delimiters changes then it might not work as expected.
Checkout this @bibinthomas
City Name
System.Text.RegularExpressions.Regex.Replace(System.Text.RegularExpressions.Regex.Match(ZipCode,"^\S.+(?<=\b.[A-Z])").ToString.Trim,".[A-Z]+$]","").Trim
State Name
System.Text.RegularExpressions.Regex.Match(ZipCode,"[A-Z]+(?=.\b\d)").ToString.Trim
Zip Code
System.Text.RegularExpressions.Regex.Match(ZipCode,"\d.*$").ToString.Trim
Thank you so much once again @Sudharsan_Ka :slight_smile:
