How to solve this problem with studio…process not opening from folder…thx in advance
Is that the system is having the UiPath studio Installed?
If not you have to install the studio to install
If installed then right click on the Main.xaml file and select openWith and click on choose another app, there you can select the UiPath Studio
Hope this may help you
Thanks,
Srini
Hi @Bh_P
Hope in your System UiPath is Installed.
IF the Studio is not installed please download the Studio from UiPath.
Thanks
VP
Hey @Bh_P ,
The default application to open .xaml types of files might be selected as IE or edge.
What you need to do is:
Happy Automation!!
Thanks,
Aditya
Click on open in UiPath studio…navigate to the required folder and then select the project.json file to open
