As you can see on the screenshot below. There is an attribute values field which can be drag in order to extend the width of the field. Now how we simulation a click and drag on uipath ? Any idea thanks ?
@Jelrey Which value do you want to Select from the Dropdown ? Are you able to indicate any of the dropdown Values by using a Click Activity ?
