How to send body using POST method of HTTP Request activity
Hey Neha,
Did you find out the solution for your problem? . It would be a great favour if you can share the solution for the above problem.
Thanks
I don’t know whether this solves the issue or not, but will help you for sure
Hi Neha, Even I am facing the same issue. And also could you please tell me hw you bale to pass the json object in the body.
Hello ,
Here you have a playlist with 10 videos all working with HTTP Request working with Salesforce, ServiceNow, and Jira. So you can see exactly how I work with parameters all videos have Chapters to be able to find very fast what you want.
Thanks,
Cristian Negulescu
its throwing error for me
Hi @malhotraneha162000,
Try the below format to pass Dynamic Variables:
“{ ““body””: ““Test””,”“subject”“:”“” +subject+ “”“, ““topicId””:”“” +topicID+ “”“, ““submitter””: “””+ submitter+ “”“}”
For Dynamic Variables, we have to provide double Quotes 3 times in body format. Then it can provide the final output with one double quote. Then bot will consider it as a proper JSON Format.
Hello Team,
I’m facing issues while passing the below json to body parameter, any pointer would be really grateful.
“name”:“Test”
“parent_id”: dynamic value.ToString
“type”:“112”
“roles”:{
“Testing”:{
“field_1”:“1234”
“field_2”:“test”
“field_3”:"test
Thanks,
Gokul
Heyy @gokul3
Just pass the same json in a single line instead of passing in multiple lines.
Let me know if that works
@HareeshMR Thank you so much for the response.
I tried giving it in the single line as suggested, I’m getting a new issue “end of the expression expected”
Body format is form-data:
{“name”:“Test”,“parent_id”: “12312”,“type”:“112”,“roles”:{“Testing”:{“field_1”:“1234”,“field_2”:“test”,“field_3”:“test”}}}
Hi Everyone,
i was facing this issue while facing the Payload in “application/text” format by giving the body as below.
{“code_type”: “add”,“process_id”: 81,“code_status”: “inprogress”,“run_startdate”: “2022-08-17T10:21:01.006214700Z”,“log_level”: “”,“message”: “”,“devicerunner_name”: “scalp”,“input_transactions_count”: 2,“environment”: “dev”,“comments”: {}}
But i am getting issue while passing this as an input, Please anyone help me to resolve this issue.
Sai
Hi Everyone,
Hope you are doing well. I would also like some help to format the body request I am using.
{“universe”:[“HK0000048691=TMKR”, “HK0000051406=TMKR”],“fields”:[“MATUR_DATE”]}
i have tried using double quotes but are still experiencing issues.
“{”“universe”“:[”“HK0000048691=TMKR”“, ““HK0000051406=TMKR””]”,““fields””:[““MATUR_DATE””]“}”
Hope someone can help me on this.
Thank you so much in advance!
I would recommend you to store the body response in a variable first and pass those variables to the keys accordingly. So every time when you will get a new result it will first be stored in variable and then they will be assigned to the keys.
@Bhaskar_Mukka
Please Make sure you have valid authentication, correct syntax and data, and all mandatory input parameters have been filled.
@encastillo2
Try by this way which I wrote below for you.
{“universe”:[“HK0000048691"=“TMKR”, “HK0000051406”="TMKR”],“fields”:[“MATUR_DATE”]}
