Hello all,
i want to invoke a workflow for each excel row, and i need to send all the values of that particular row. is there any way to send the excel row itself as an argument.
Hello all,
Hey @Sai_Prakash1
Just create an argument of type DataRow
and the Foreach CurrentRow
can be passed into the workflow.
Hope this helps.
Thanks
#nK
Hello @Sai_Prakash1
Are you using Reframework if, you need to change the TransactionItem variable Datatype to DataRow(By default it will be Queue Item).
If not using Reframework, if you are using Foreach Row in datatable, the item will be a datarow, so you need to create the argument as Datarow.
Thanks
